OK, OK, I hate to admit this, but I am stumped. There must be a method to the maddness, I just don’t know what it is. I have a 69 Cutlass S with the 350 engine automatic trans which has a floor mounted shifter & console. The problem is that I can’t get the cable to shift the right way. The trans does shift if I do disconnect the cable & shift it by hand, so I know the trans is OK. I know there is a “trick” when installing these GM cables, just can’t remember what it is. HELP !
Related topics
| Cannot shift....unless I | 1 | 506 | July 25, 2010 | |
| Transmission cable? | 1 | 294 | July 5, 2007 | |
| Shifter cable addjustment | 0 | 237 | August 22, 2007 | |
| How do I remove the gear shifter for my 97 Cutlass Supreme? | 1 | 1087 | November 20, 2012 | |
| "Can't Replace / Fix Shifter Cable - Have to Replace [Auto] Transmission" | 7 | 7802 | December 6, 2010 |
