I have a car question that I can’t seem to find the answer anywhere. I own a 2003 Dodge Stratus 2.4 Liter DOHC in which started giving me problems about a month ago. Whenever the car reaches a good running temperature or after i have driven it for about 30 minutes some type of limiter will kick in and keep the car from reving over 2500 rpm’s. The car’s computer readout suggests that it is the cam shaft position sensor that is triggering it, but i have replaced the camshaft position sensor the crankshaft sensor and the timing belt to no avial. Can you please help?
Related topics
| Would not go above 2500 rpm (this was a post by someone else but eerily similar issues) | 13 | 6279 | February 11, 2016 | |
| Engine Light on-Accerleration Choking wont go past 2rpm from time to time | 3 | 1331 | August 17, 2016 | |
| Car won't rev past 2500 RPMS | 36 | 36793 | April 20, 2017 | |
| 2004 dodge stratus won’t hot restart (2.4l) | 0 | 267 | July 9, 2019 | |
| Engine surging | 1 | 492 | June 21, 2010 |
