My 2001 9-3 (52k miles) has repeatedly triggered a check engine light.  Actron shows it as P0101, MAF Ckt Rng/Performance.  I?ve cleaned the MAF twice w/MAF cleaner.  Stock air filter.  Even after clearing the codes my Actron quickly shows code ?pending?, P0101.  Freezing the data shows:
 MAP KPA 52
 STFTRM1% 0.0
 LTFTRM1% -21.7
 STFTRM3% -100.6
 LTFTRM3% -100.6
 Short term/long term fuel trim looks like a clue.  Am I able to check my MAF or the connector cable with my multimeter to see what is bad?  Volts, amps, or some other test?  Are these MAFs know to go bad?
 I see some ?reconditioned? MAF?s available on-line.  Is that a reliable fix?  What does the reconditioning entail?
