Hello,
I just replaced old headlights on a 2007 honda fit with LED bulbs and was wondering if there is a different version of the rubber bulb cover for led lights? I can’t fit the rubber cover back on due to the plug and cord. What are my options?
Thank you
              Option 1: make a hole in the old rubber cover and pass wires through it
Option 2: use old rubber cover, unmodified, remove LEDs and relieve the oncoming drivers from the excessive glare it will make in the headlights not intended to install LEDs
personally, I strongly advise toward #2
There will not be a different cover because your vehicle was never meant to have LED lights in the first place.
              I had no idea, thank you for the feedback
