I have a 2002 Kia Rio. I changed the rear (drum) brakes 3 weeks ago. In the last week and a half, I have noticed an increasing amount of noise that seems to be coming from the rear driver side wheel. It’s now loud enough that I can’t ignore it anymore. As a “learn-as-I-go” mechanic, I was surprised to find I had to remove the assembly/part with the bearings on it to get the drum off (my other, American, car does not work this way). I am concerned that I got the nut back on either too tight or too loose and this is affecting the wheel. What do you think? Thanks.
Related topics
| Rear Wheel noises -- bad bearings? | 11 | 2035 | December 7, 2021 | |
| Pontiac Sunfire noise from rear wheel | 2 | 1893 | June 8, 2009 | |
| The never ending car problem | 4 | 1039 | August 29, 2007 | |
| HELP! Rear tires making a metal dragging noise/ grinding. NEW BRAKES AND DRUMS | 65 | 64210 | May 17, 2023 | |
| 2005 murano wheel bearing | 10 | 4034 | January 6, 2012 |
