Recently I bought a set of those higher intensity low beam bulbs but when I sought to have the dealership do the replacement their charge was $110.00.Needless to say I opted out. But checking outside the dealership the cost is fairly comparable. Can this,apparently time consuming,operation be done by the layman or is it ‘skill specific’.
If your owners manual is worth the paper it’s printed on it will tell you how to do this.
The OM for my wifes 02 Sonata even has detailed instructions for aiming the headlights.
You were right!!! Apparently it IS,at least, worth the paper upon which it’s printed. Thanks very much.
Good deal & it looks like you just saved yourself 110 bucks.
Good luck with the swap.
