I have a 2007 Hyudai Azera that I believe an important document slipped into the console. I cannot figure out how to get into the console. Can somebody help?
Is a call to the service/parts department of a nearby Hyundai dealer worth a try ?
Next would be an auto body shop…I’ve had good luck with like questions with them as many cars have similar interior parts.
THANKS I’LL GIVE THAT A TRY
This isn’t going to be easy.
I looked this up and, even if you pry the center console bezel of the center console off, the center console itself doesn’t provide a large enough opening to pull out a single sheet document. The entire center console requires removal.
THANKS A LOT; IS IT DIFFUCULT TO REMOVE THE CONNSOLE?
No. If you have the proper information and tools.
Yes. If you don’t have the proper information and tools.
