vehicle chugs/hesitates mostly at idle lower speeds. autozone computer check gave following codes: PO107; PO121; PO123
THANKS FOR ANY HELP.
OBD2 Code Translation
My OBD2 book says:
PO 107 - MAP / Baro Circuit Low Input
PO 121 - TPS / Pedal Position Sensor A CKT Range / Perf
PO 123 - TPS / Pedal Position Sensor A CKT High Input
Click the link below and go to one of many sites that could steer you in the right direction.
Click “Trouble Codes” at the top and scroll down for a complete list and links to help advice.
Reply with more questions if you’ve got them.
CSA
