I am simply trying to remove my ignition coil. I have removed both bolts, and just need to know if there are any other bolts or anything holding it in place. Can’t seem to get it loose.
The ignition coil is attached in the corners to it’s bracket with four bolts and nuts or sometimes with four rivets which must be ground off. New coils are often supplied with new attaching hardware.
