Recalls for 2012 Nissan Maxima
i just bought a used 2012 nissan maxima and i want to know if they issued a recall or offered to repair this issue if not i guees i just got robbed for 12 grand ugh i did purchase extended warranty although i dont know how it works
I hate having that issue also, I find using Imodium A-D works pretty well.
Or do you have a different issue?
You can check for incomplete recalls on your vehicle at the manufactures site;
https://www.nissanusa.com/recalls-vin/#/#/Home
A recall is not going to compensate for paying $12,000 over retail value if that is your only issue.
Well the issue is unknown because you did not say what it is . I guess if you read the paper work you should have about the extended warranty that will give you an answer .
Just in case you did not notice all of the replies used Capital letter and punctuation where needed.
You can look up recalls on the NHTSA website by entering the Vin # here
Ed B.
Why did you buy it with a known, to you, defect that had not been repaired?
