Rear oil passage cover
Does anyone know anything about a rear oil passage cover is on a 2006 honda civic. Went to local dealer and had oil leaking under car . They told me it was coming from the rear oil passage cover. I searched all over the net and no luck on the part. They told me it will cost over $300 in labor they said there isnt a gasket on it just some tube seal . Can anyone help me please
It’s called the rear oil/air separator cover.
http://search.aol.com/aol/imageDetails?s_it=imageDetails&q=2006+civic+oil%2Fair+separator+cover&img=http%3A%2F%2Fcivic.hondafitjazz.com%2FA00%2FPNG%2FSNB6E30A32200043711KCAD02.PNG&v_t=customfirefoxright-ff&host=http%3A%2F%2Fcivic.hondafitjazz.com%2FA00%2FHTML%2F30%2FSNB6E30A32200043711KCAT00.html&width=181&height=140&thumbUrl=https%3A%2F%2Fencrypted-tbn0.gstatic.com%2Fimages%3Fq%3Dtbn%3AANd9GcS8Bu0BBwx-vNZS4zZFSYeI7yvjfZHdYt8gTDTtaWmpq0oxrBT4RYa_FLxj%3Acivic.hondafitjazz.com%2FA00%2FPNG%2FSNB6E30A32200043711KCAD02.PNG&b=image%3Fq%3D2006%2Bcivic%2Boil%2Fair%2Bseparator%2Bcover%26v_t%3Dcustomfirefoxright-ff%26s_it%3DimageResultsBack%26oreq%3De0541715ea1c4507b45cb36ff2afe990&imgHeight=369&imgWidth=475&imgTitle=6+x+1.0+mm+9.8+N·m&imgSize=4457&hostName=civic.hondafitjazz.com
When these leak, you remove the bolts and cover, clean the mating surfaces, apply a sealant to the cover and bolt holes, and reinstall the cover and bolts.
Do u have to remove the manifold and starter ??
I can find no reference on removing the starter or manifold when re-sealing the cover.
So, it might be accessed from under the vehicle.
