I am going through and replacing all lights with LEDs in my vehicles and have run into somewhat of a mystery with my 1999 F250 Super Duty. The dome light works just fine and always has but the reading lights didn’t work. I figured it was just bad bulbs. New bulbs didn’t solve it. I read that the switches in the overhead light assembly can get corroded and dirty over time so wondered if that was it. Someone offered to give me the light assembly from a junker they didn’t want. I went and looked at it and it was from a similar year F150. The light pod was IDENTICAL so I took it. Before removal, I hooked up a battery and tested to see if the dome lights and reading lights all worked. They did so I figured it was all good. I took it home and installed it but the reading still lights don’t work.
I figured they would all be powered off the same fuse but there was some confusion in the information I found while looking into this. It looks like some say these lights are controlled by fuse 4 and others say 14. I decided to pull fuse 4 and the dome light would no longer work. I then pulled fuse 14 and it was the same. Both these fuses were obviously good as both must be present and not burned out for the dome light to work.
I can see that the power and ground are all run through the three screws that attach the light assembly to the roof. All those are tight and I would assume that the dome light wouldn’t work if there was a connectivity issue here.
So, I took an identical part that was clearly working fine in the donor vehicle but the same issue is now going on once installed in my truck. The dome light works normally but the reading lights on the side don’t. What did I miss here?
This isn’t a huge priority for me but a minor annoyance. All other lights are working including the ones that really matter for safety and being legal on the road.
The Generic Electronic Module (GEM) is the central brain for your truck’s body and cabin electronics. It does not control the engine, but it manages a wide range of functions that you use every day. This includes the windshield wipers and washers, power windows, power door locks, interior dome and courtesy lights, the 4x4 system, and the warning chimes. The GEM receives inputs from switches (like the window switch or wiper stalk) and sends commands to the corresponding accessories. When it fails, it can cause a host of strange, seemingly unrelated electrical problems.
That wouldn’t surprise me. I ran into this with my old 1997 that got junked, That GEM had gotten wet from a windshield leak and was never right after that. It had more electronic stuff compared to this one which has manual windows and all. I had the windows just roll down one day right before a big storm was predicted. I had to power the window motor directly to another battery I had sitting around to roll them up, then I left them disconnected.
Besides the dome light issue I cannot see a lot of other things that are acting up but the GEM is a very reasonable explanation.
I will do this next. I also see relay R1 as something I need to checkout since this appears to control interior lights. The fact the dome light works when you open the door so I assume it works but will definitely check and swap with another to verify.
Your bench test was the right move, and it tells you more than the fuse hunt will: the pod itself is good. Bulbs, both switches, and the pod’s internal ground all worked off a battery, so another assembly won’t fix it. The fault is on the truck side of that connector.
So measure at the pod connector instead of working the fuse boxes. Key on, meter the pod’s feed pin to battery negative with the switch pressed and you should see full battery voltage. Then meter the pod’s ground pin to battery negative with the switch pressed and you want under about 0.1 volt. Whichever one fails tells you which circuit to chase, and you stop guessing between GEM, relay and fuse.
Worth splitting out one thing: the dome working proves the interior lamp feed is alive at least to the dome’s branch on that assembly. The reading lights ride their own switch legs inside the pod and return through the pod’s ground, so the open circuit is most likely at the connector or the ground return, not inside the GEM. A GEM is a lot of money to spend on a hunch. Feed and ground first, then the relay swap you already planned.
Thanks. I don’t think I would buy a GEM for the truck at this point no matter what. I might know of a used one that would drop in but it would have to be pretty much the same basic options mine has to just drop in and work.
Those are all good suggestions and I will look into testing voltage from the truck with the dome light pod removed latertoday. I had an extra relay from a truck I recently junked and it made no difference at all. Of course with the relay out nothing worked so I know I had the right one there.
I would hardwire the switch to a new relay inside the pod and control the lights that way before I would pay for a replacement controller. Return to local control…
the GEM from the pod donor truck is not available anymore? or it’s a completely different configuration?
The other truck is a regular F150 with a lot more options on it so would assume that is a no-go. My truck is all manual windows and locks. It has electronic windows and locks so I assume it wouldn’t interchange.
On the other hand it looks like that style of light pod was pretty much used on every Ford of that vintage.
I’ve replaced every incandescent bulb in my '23 truck from the firewall back to the rear bumper with LED bulbs, mainly cause the interior is mostly dark colors and the stock bulbs suck and I like being able to see what I am looking for when it is dark or light outside and the stock bulbs are all but useless, very dim… LED’s are a night and day difference…
I also did an upgrade kit for the tail/brake lights and rear turn signals, the stock set up is awful, you had 2 tail light per side, bottom one was the brake light and the top bulb was the turn signal… Now the turn signal has been moved from the tail lights to the reverse lights (white for reverse and amber for turn, duel color bulbs), and now it uses all 4 tail lights for the brakes, so double the lights plus LED vs incandescent bulb, WAY more visible to those distracted drivers… So much safer I would think…
BTW, the kit comes with resisters so hyper flash is a non issue…
I never did upgrade any other vehicles I’ve had with LED bulbs, but it sure would have been nice to of been able to see in the Vibe/Matrix, it has an all black interior and you couldn’t see much of anything without using a flashlight etc when it was dark outside… If I had to start driving it again I would probably upgrade the interior bulbs to LED’s…
Here is the difference between the stock vs LED map lights for the 2016-2023 Tacoma’s… Same difference with the dome and vanity lights…
