My 2008 Nissan Altima had a rapidly flashing right front turn signal. I assumed it was a bulb, but bulb was fine (i went ahead and put a new one in anyway). still flashing rapidly. i’m reading it could be a relay. Under hood fuse box schmatic shows “H” relay contols that but I’m seeing conflicting info on relay. Am I right about relay or could it be something else. If a relay, which one location of it. Thanks guys
Welcome..
Have you checked your rear turn signals??
just checked and passenger rear not working either
Also, when pressing the ignition button lately it doesn’t stat sometimes,
Just now had to press it four times and hold fob up b4 it started
Sounds like your front maybe flashing possibly due to the rear not working at all..
Replace all burned out bulbs and see what happens…
Try a different (spare) key fob to see if it starts normal, and or replace the battery (battery plus does it if you can not) in your fob to see if it helps…
Thanks Dave. Just got back from Advanced Auto with the rear bulbs
I’ll try the key fob switch
Update?? ![]()
