I ran out of gas. Now the engine won’t run unless I constantly pump the gas peddle. When I stop pumping the engine stalls. I have a 1994 eagle Vision 3.3
Change the fuel filter. Check your Haynes, or Chilton’s, repair manual for bleeding air from the fuel system. Also, check fuel pressure, and the throttle position (tps) sensor, and the idle air control (iac) valve with a digital multimeter with the instructions in the repair manual.
Consider the value of the vehicle before you spend any money on a rebadged Intrepid. It’s an opportunity here. It may be time to move up.
