Radio noise from other devises such as turn signals
Do I have a bad ground connection that is causing noise over the radio when operating other electrical devises such as turn signals?
That’s what usually causes radio interference when other electrical systems are operated.
Is a turnsignal relay to expensive to just give it a try? With bad grounds I always wonder what made them get bad.
How do you isolate the various trouble sources?
