“I’ve given up on having Ford help, so i’m about to just replace the ignition on my own dime. If i didn’t put $25k into it already, i’d just make the dealer take it back under lemon laws.”
A few thoughts (and questions)…
Exactly what did you spend $25k on?
I hope that you did not do any modifications that might have compromised the warranty.
Can you clarify exactly what you did that cost $25k after you bought the vehicle?
When you say that you’ve “given up on having Ford help”, I  assume that you mean the Ford dealership, as you made no mention of having contacted anyone at the corporate level.   If my assumption is correct, you need to open your Owner’s Manual, find the contact information for Ford’s Customer Assistance department (or whatever they are calling that part of their organization at this point) and make contact with them.
First, initiate contact via a totally non-emotional, totally factual phone call.
Then, follow up your phone contact with a well-worded, non-emotional letter informing them of your dissatisfaction with the vehicle, and requesting the intervention of the Zone Manager.
I would advise you to NOT replace “the ignition”  (presumably the ignition switch), as that will only complicate matters.   Ford should be the only entity that is working on your vehicle at this point.
And, the Lemon Laws actually don’t have anything to do with “the dealer taking it back”, as the vehicle’s manufacturer is the party that designed, manufactured, and warrantied the vehicle.  Typically, these statutes require that you give the dealership 3 tries at rectifying a defect before you can file a Lemon Law claim, but this will vary somewhat from state to state, and if you haven’t yet had it in the dealer’s shop for a repair attempt, then the clock isn’t even ticking yet on a possible Lemon Law claim.
So, begin by contacting Ford at the corporate level,  drop your car off at the dealership so that you have the first (of 3) repair visits under your belt, and additionally start doing research on your state’s Lemon Law.    If there are 3 documented unsuccessful repair attempts, you should (depending on the statute in your state) be able to get a new replacement vehicle, or receive a full refund of your original purchase price.
