I have started this question again as I have more info. My power door locks stopped working on my 2001 Ford Expedition. All 4 do not work as well as my key fob and my external keypad. The key works fine and does lock/open the door. I can trace the clicking to the anti-theft module under the firewall. When I disconnect the wiring harness from the module, the clicking stops. Fuses look good in both the fuse box under the dash and under the hood. I don?t think it is the relay as (per the owners manual), the relay also works the seats and pedal which work fine. My question is…do you think the module is the problem? If I replace the module, do I need to reprogram the keypad entry code? Help…not sure what this module does…any help is appreciated.
Related topics
| Power Door Locks | 8 | 1379 | July 6, 2011 | |
| 2000 Ford Expedition key fob | 1 | 455 | March 30, 2018 | |
| Power door locks possessed | 5 | 1226 | August 20, 2007 | |
| Power locks draining battery? | 5 | 13544 | October 30, 2007 | |
| 2004 Ford Expedition - Electronic gremlins | 2 | 532 | December 20, 2020 |
