Please help!
I accidentaly hooked the cables up backwards when jumping off my 2001 kia optima. Now it will not crank. someone mention something about a reset switch or button but havent had any luck finding it. The car has been parked for close to 6 months.
Thanks,
Eric
Fusible link. It’s the small red wire coming from the battery + terminal to the relay box under the hood. You can test it with a simple ohmmeter (disconnected from the battery, of course). If it needs replacing, be sure to use the correct one. It is NOT just a wire.
gonna give it a shot. Thanks
