I park on the street and my bumper gets knicked a lot. I had a horizontal crack in the paint, about four inches long. A year later the paint has peeled from an area of about 4 inch by 1.5 inch around the crack.
The bumper itself is solid, no damage. Just the paint is damaged. How can I stop the paint from peeling? I don’t want to repair this, because it will happen again for sure. I just want to stop the paint from peeling and the crack from getting larger.
Thanks RemcoW. I don’t desire it to look perfect… or even good. I just want the chipping/peeling to stop, so the damage doesn’t grow. Any suggestions for that?
@jeff1
As you stated you dont want to repair it so try this. Break off all the paint that is lifting and loose, use whatever tools you need since your not repairing it.
After you have removed the loose stuff and cleaned the dirt off paint the edges with clear fingernail polish. That should hold it for awhile.
As meanycatz said, you have to remove the loose paint and do a touchup. In your case the bond between the paint and the underlying surface was broken by physical stress rather than a poor bond, so the problem should be isolated to those the areas surrounding spots that were hit. Since it’s a recurring problem, I’d just get some rattlecan touchup paint and try that. Be sure to use primer too for better adhesion.
