P0340 code...now what
The Camshaft Position Sensor fine tunes the injector pulse widths.
@tester: How does the CPS fine tune the injector pulse width?
I understood the CPS pulse fed the ECM the cam/cylinder position, but that pulse width computation was derived from the other sensors (like throttle position, vacuum, engine rpm, O2, etc).
Is there something about the CPS that enables the ECM to compute pulse width?
