how do i change the battery, it is different from other cars?
Remove the fuse/relay box from the round support bar and remove the support bar after to gain access to the battery.
Remove the battery cables and the battery hold-down clamp, then exchange the battery.
Thorouhly clean the cable connectors before attaching.
Installation is the reverse of removal.
It depends on the year/make of your vehicle. Disconnecting the battery can cause all sorts of headaches on some vehicles. I now automatically connect a battery back-up on any vehicle where the battery has be disconnected to prevent potential problems. You can read what can happen when disconnecting/changing a battery on a vehicle here. http://www.aa1car.com/library/battery_disconnect_problems.htm
