Hi!
When I start the car, after a few seconds starts a high frequency noise. The noise is located in middle right low part of the car.
Here is the recording of the sound: https://vimeo.com/169508427
The noise gets stronger after 14 sec of the video- when i get closer with recorder,…
And the image of the possible location:
[url=http://postimg.org/image/x6q1v9bez/]
The image is near fuel tank, but doubt it has to do with the sound.
Thank you
The quality of that recording is…not good…but, based on what I can hear, as well as your statement that the noise is coming from the area of the fuel tank, I think that the noise is likely coming from a failing electric fuel pump. I would suggest checking the fuel pump now, before it fails and winds up stranding you, and before you need to spend extra money to have the car towed to a mechanic’s shop.
+1 to VDC’s post.
As regards getting a new pump on order ASAP, that’s a good idea, because you face the additional challenge of actually finding one… and then waiting for it to get shipped from France.
Sincere best of luck with this.
