Can the reason my Honda Accord 97 not accelerate due to oil pressure not installed correctly? Thankyou
You question doesn’t make much sense. Oil pressure is not “installed” it is created by the oil pump to lubricate the engine. If there isn’t enough oil volume or pressure, (or the level is too low) the engine will not accelerate very well and quickly stop all together.
Your title says “Oil Pressure Sender Replaced”
If you want to know if that is the reason for poor acceleration, I’d say no.
If your Honda has a problem accelerating, I’d suggest you take it to a good independent auto repair facility for a diagnostic to find out the actual problem.
No, your acceleration problem is the problem with the brakes as identified in your other thread.
