2003 PT Cruiser won’t start immediately after short trip with a short stop. Always does start after turning the key and holding it to start position. The check engine light is often on and the code is for a cam shaft sensor or resistor sensor. A companion problem is the cruise control. If the check engine light is OFF and I use the cruise control, it works fine for a while and then the check engine light comes on at the same instant the cruise control turns off. Are these 2 issues connected? How much should it cost to have the sensor replaced? The car always stays running once it starts and the problem occurs randomly. What are the consequences of not repairing it?
That CEL (check engine light) is just a kid in class waving her hand trying to get you attention because she has the answer. You need to have the codes read. Some places will read them for FREE. Try Autozone or Advanced Auto Parts. Get the exact code (like P0123) not just their translation into English and post it back here.
