OBD2 scan help (shorts and BCM)
I pulled these codes off my 2013 Ford Fusion Hybrid and it all seems to point to the BCM and I don’t know what the 72E refers to. The car is showing a static check engine light and wont let me start it, with a " stop safely" error message. The car is still getting power but the engine wont turn. Anywhere I can start before having it towed to a shop? Thank you!
Ford Fusion Hybrid SE,2013
Extended diagnostics
B124D - Tire Pressure Sensor General Signal Failure : General Signal Failure (72E - BCM,SJB-body)
B1310 - Power Door Unlock Circuit Failure : Circuit Short To Ground or Open (72E - BCM,SJB-body)
P0230 - Fuel Pump Primary Circuit : Circuit Short To Ground or Open (72E - BCM,SJB-body)
U3007 - Control Module Input Power B : Circuit Voltage Below Threshold (72E - BCM,SJB-body)
U3013 - Control Module Input Power C : Circuit Voltage Below Threshold (72E - BCM,SJB-body)
B1C55 - Horn Relay : Circuit Short To Ground or Open (72E - BCM,SJB-body)
B130F - Unknown trouble code (72E - BCM,SJB-body)
B1435 - Wiper Hi/Low Speed Relay Coil Circuit Open : Circuit Short To Ground or Open (72E - BCM,SJB-body)
B1430 - Seat Belt Switch Circuit Short To Ground : Circuit Short To Ground or Open (72E - BCM,SJB-body)
B1444 - Door Handle Switch Circuit Short To Battery : Circuit Short To Battery or Open (72E - BCM,SJB-body)
B1448 - Wiper Park Sense Circuit Short To Battery : Circuit Short To Battery or Open (72E - BCM,SJB-body)
B1215 - Running Board Lamp Circuit Short to Battery (7D8 - APIM-accessory)
Tow it to a shop.
You don’t have the equipment to program a replacement BCM if it requires replacement.
https://www.fofusion2.com/ford_fusion_body_control_module_bcm_removal_and_installation-2667.html
Measure the voltage at the 12 volt battery, low voltage won’t allow the computers to operate.
Good idea above to check the 12 volt battery. In addition, blown fuse(s) could prevent electrical power from getting from a good battery to one or more of the electronic modules. Have all the main power fuses been checked?
Given the fuel pump problem, it is not surprising the engine won’t crank and run.
I expect that is just the computer’s numeric ID for the BCM.
Did anything unusual occur just before noticing these symptoms? Like getting or giving a jump start?
Thanks for the responses. The battery was measuring 11.4v, so I replaced it and it’s 12.2 but didn’t relieve the problem. Fuses all appears to be good. Nothing unusual happened that led to this, my wife just started it up and got the “Stop Safely” error and it died.
I ran another OBD after swapping the batteries and now there are additional errors. Looks like I just need to have it towed to the dealer, especially since I am moving next week and can’t pay much attention to it. Thanks again for the help!
  • 931014 931014 → B1310-14 (48) Power Door Unlock Circuit Failure : Circuit Short To Ground or Open (72E: BCM,SJB-body)○ confirmed DTC
  • 023014 023014 → P0230-14 (C8) Fuel Pump Primary Circuit : Circuit Short To Ground or Open (72E: BCM,SJB-body)○ confirmed DTC
  • F00716 F00716 → U3007-16 (08) Control Module Input Power B : Circuit Voltage Below Threshold (72E: BCM,SJB-body)○ confirmed DTC
  • F01316 F01316 → U3013-16 (08) Control Module Input Power C : Circuit Voltage Below Threshold (72E: BCM,SJB-body)○ confirmed DTC
  • 9C5514 9C5514 → B1C55-14 (08) Horn Relay : Circuit Short To Ground or Open (72E: BCM,SJB-body)○ confirmed DTC
  • 930F14 930F14 → B130F-14 (08) Unknown trouble code (72E: BCM,SJB-body)○ confirmed DTC
  • 943514 943514 → B1435-14 (08) Wiper Hi/Low Speed Relay Coil Circuit Open : Circuit Short To Ground or Open (72E: BCM,SJB-body)○ confirmed DTC
  • 943014 943014 → B1430-14 (08) Seat Belt Switch Circuit Short To Ground : Circuit Short To Ground or Open (72E: BCM,SJB-body)○ confirmed DTC
  • 944415 944415 → B1444-15 (08) Door Handle Switch Circuit Short To Battery : Circuit Short To Battery or Open (72E: BCM,SJB-body)○ confirmed DTC
  • 944815 944815 → B1448-15 (08) Wiper Park Sense Circuit Short To Battery : Circuit Short To Battery or Open (72E: BCM,SJB-body)○ confirmed DTC
  • 915E08 915E08 → B115E-08 (08) Camera Module Bus Signal/Message Failure : Bus Signal / Message Failure (72E: BCM,SJB-body)○ confirmed DTC
  • C12187 C12187 → U0121-87 (08) Lost Communication With Anti-Lock Brake System (ABS) Control Module : Missing Message (72E: BCM,SJB-body)○ confirmed DTC
  • C13187 C13187 → U0131-87 (08) Lost Communication With Power Steering Control Module : Missing Message (72E: BCM,SJB-body)○ confirmed DTC
  • C29387 C29387 → U0293-87 (08) Lost Communication With Hybrid Powertrain Control Module : Missing Message (72E: BCM,SJB-body)○ confirmed DTC
PAM-parking assistant(73E)
  • C10000 C10000 → U0100-00 (28) Lost Communication With ECM/PCM A (73E: PAM-parking assistant)○ confirmed DTC
  • C12100 C12100 → U0121-00 (28) Lost Communication With Anti-Lock Brake System (ABS) Control Module (73E: PAM-parking assistant)○ confirmed DTC
APIM-accessory(7D8)
921500 921500 → B1215-00 (28) Running Board Lamp Circuit Short to Battery (7D8: APIM-accessory)○ confirmed DTC
That voltage is too low for a new battery. Should be closer to 12.6 volt. Something remains amiss w/battery or charging system. What voltage does battery measure when engine is warm & idling?
12.6 volts with no load, but with the battery installed and the trunk open 12.2 volts is reasonable. There is sufficient power to operate the computers.
If the engine was operating, he wouldn’t be working on the car. The auxiliary battery is charged by the inverter, the engine doesn’t need to be idling.
