- The AC on the driver’s side on Valerie Odyssey 2007 is not blowing cold but the passenger side is.
- Therefore I’m assuming it’s not for a lack of Freon if one side is cold.
- I took off the actuator and manually moved the levers and I can get it to blow warm or neutral but never cold. That’s what is stumping me. Why would it not blow cold by manually changing the levers? I was intending to replace the actuator but if it’s still not cold then what good would that do? Unless there’s something in the actuator that says “ kick in the ac” and without it – it just blows.
I’m a real novice at this so please speak car 101 back to me…thanks
