Nissan Versa Spring Recall and Alignment
Have it aligned. I was unable to find an exploded view drawing of the 2010 Versa, but every versa I was able to find of the same era had struts. Struts need realignment after changing. It isn’t just you. The vehicle needs to be realigned.
You should petition the manufacturer to include this in the recall compensation to the dealer using the complaints procedure that came with your owner’s manual, but if they decline it’ll be worth the cost anyway.
