I am looking for a little advice regarding my 2010 Nissan Titan.
Here is the back story
I began having issues with it turning over and not starting from time to time. I needed to change the battery and ironically it started fine for about 2 weeks then the problem came back. Finally it happened more and took me sometimes it took me a while to start it. Then nothing.
I towed it to a electrical auto place which they traced it to the ECU. So I sent it off to be refurbished which they told me it couldnt be repaired so the to another refurb, programmed it and I got it back today. I tried for about 10min and nothing. Then is started yet sounded sluggish for about 3 seconds. Turned it off again and it didnt work. Got it started and let it run for a while so that part is fine so I am assuming that issue is fixed.
So here is the new issue that I question. Before this happened it turned over quick but when I got it back from the electric place when it turns over it had a deeper tone that different. Now when it starts it takes a 1-2 seconds over turning over to start.
For anyone that knows can you suggest a list of easy inexpensive things I can throw at it? While is seems “OK” something is still off.
