Posted a question about my clutch about 8 months ago: http://act…48785.page
Had my master cylinder replaced by the dealer. (Thanks for your advice.)
In the past two days, when I push down on the clutch pedal, it sometimes blocks. I can’t push it down. Then, it “gives” and I can push it all the way down. I thus continue on my way. However, I find this “blocking” reaction disquieting and do not want to go on driving the car if there is any danger.
What do you think is the problem?
Many thanks for your help.
Well, someone who knows the system just has to inspect it. If the blocking feels very firm, like a physical blockage its likely to be some part of the physical clutch mechanism binding. It could be as simple as something inside of the car at the clutch pedal or as annoying as a bad release fork (which would likely require more major surgery). The only way to figure it out is to inspect.
I would not feel safe driving this way.
Thank you very much for your advice. I shall heed it. Have an appointment with the garage. In the meantime, I will not drive the car. Better to be safe.
Much appreciated.
