Hey, I’m a newbie here. I absolutely love CarTalk and figured I could give this form a try
I’m having a very interesting situation with my 2010 Nissan Versa Hatchback S,118,000 miles. I’ve owned the car for over two years and its been a trooper. As of lately though, the clutch started acting up. It would get spongy and wouldn’t allow me to engage a gear change till the peddle is at the firewall or on a few occasions, I couldn’t engage at all. But I would only have these spongy clutch problems after I’ve been going 70mph on the interstate for more than 30 mins. And when I do get the spongy clutch, if I pull over and pump my clutch the pressure comes back and I can shift like normal again. But another bizarre thing is there are no leaks in the fluid. Over the past several weeks, I’ve been checking the fluid and its spot on max every time. And If I spend a week driving around town, my clutch is normal. I’ve been surfing the net and can’t find anyone else who has had the same symptoms. I’ve talked to a bunch of my car mech friends and my dad. Everyone seems baffled and just suggested to by a new clutch kit and replace it.
I decided to start with buying the less expensive stuff first to replace before committing to a whole clutch replacement kit.
I started with the Master Cylinder. My dad and I replaced it two weeks ago and bled the lines. And for a week my clutch was normal even after driving the interstate over an hour and a half.
But guess what?! Its back to its old ways getting spongy after long runs on the interstate.
I have no other issues with my clutch system, no slipping, nothing.
My slave cylinder is in the trans so I would just replace the clutch system anyway since it would be so much trouble to get to it. So I’m keeping the slave till last.
My dad had a new suggestion yesterday. He was wondering if debris or something might be in the clutch/break reservoir? Maybe somehow causing air intake when the engine is hot for a long period of time, and then when I pump my clutch, the air compacts or escapes?
Any other theories out there about my mysterious spongy clutch situation?
Thanks you all
