I have a 2013 Nissan Altima that’s leaking water into my car on the passenger side. I know there an AC drain there that I can see but it looks like the water is coming from above that. I am not sure where it is coming from. It only happens when I am running the AC. Any help would be appreciated.
Have you tried poking something in the drain to see if it’s plugged?
Not yet. Is it still the drain if it’s coming from above it?
If the water isn’t coming out the drain, it must be plugged.
Thanks. I forgot to update. I fished some braided lockwire up the tube from inside the car and pulled out some leaves and realeased a ton of water in my car. But the drain was definitely clogged. Drove a handful of times with AC on blast and haven’t noticed any dripping. Thanks again for your help!!!
