I Have 2004 Nissan Sentra 1.8, automatic, 36,000 miles, stalls and will not accelerate after I stop for a red light or STOP sign. This only happens when it rains. It takes a minute or more before it accelerates and takes off It also does not start right away, but takes a few cranks to ignite and turn on, this happens always. I had a mechanic check the spark plugs and sensor codes. All checked out okay.
As i researched, I read about 2 Nissan class action lawsuits
Notice of proposed settlement -Lawsuits were filed regarding the 2005-2010 model year Nissan Pathfinder, Nissan Xterra, and Nissan Frontier vehicles… lawsuits alleged that these vehicles contain a defect that permits cross-contamination of engine coolant and transmission fluid, ultimately causing the radiator and transmission to fail or need substantial repairs and further allege that Nissan failed to disclose the alleged defect to consumers. See details at http://classaction.kccllc.net/Documents/NNS0001/NNS_NOT.pdf
Consumer class action concerning secondary timing chains, secondary timing chain tensioners and secondary timing chain tensioner shoes (“Timing Chain Systems”) installed in 2004 -2008 Nissan Maxima vehicles, 2004 – 2009 Nissan Quest vehicles, 2004 – 2006 Nissan Altima vehicles (with the VQ35 engine), 2005 – 2007 Nissan Pathfinder vehicles, 2005 – 2007 Nissan Xterra vehicles, and 2005 – 2007 Nissan Frontier vehicles (with the VQ40 engine)… When the timing chain systems fail, they can cause a variety of problems, including the inability of the vehicles to accelerate and maintain speed, as well as catastrophic engine failure…
For details go to: http://www.gotaclassaction.com/nissan-north-america-named-in-class-action-lawsuit-alleging-failure-to-disclose-defect-in-timing-chain-systems-which-results-in-premature-failure/
There is no mention, of the 04 Sentra, but with all this negative info, I can’t help wonder  could the same or similar be happening to my Sentra?
Experts, please advise. Thank you.
