Most speaker manufacturers get locked up in producing acurate sound at one meter in chamber designed to prevent reflections. The world out side is filled with reflections and there is more to sound reproduction then on axes accuracy. Most Bose speakers cannot compete with the mid fi competition in that area, while most of the mid fi competition cannot compete with Bose in accuracy throughout the living environment. Try it yourself with a frequency test CD and a sound pressure meter. You don’t have to believe me, do it yourself. The equipment is cheap. Off axis high frequency is often obsorb and becomes a non factor in reflected sound…there is the reason for your, “no highs” using paper cone tweeters by Bose for example.
Head to head test a Bose 301 vs a comparable Klipsch or Polk off axis, as far out as 180 degrees. While the accuarcy is better in a narrow beam, through out the rest of the room, the Bose more often will excel. This off axes sound is then reflected producing more accurate sound throughout the listening environment. Another thing that is for sure is that Polk and the comparibly priced brands produce more listening fatique with their extended range transducers trying to generate enough high frequency dispersion using shear volume. Bose speakers try to generate dispersion by using multiply arrays at lower volume.
So, if you sit in an easy chair, don’t move and don’t mind getting a headache, regular speakers work and will give you more accurate sound. If you get up and move around, over time, you will find Bose speakers more listenable over longer periods of time and in a greater number of positions in the listening area without generating anywhere near the listening fatigue.
A freind and I have built dozens of speakers over the years using computer assisted programming which match componets, crossovers and cabinets. We even built our own crossovers. My son worked in several electronics stores and we had a chance to measure off axis response of many speaker brands after hours. Bose consistenly does better then most throughout . There was one brand that at one time, the Allison line of speakers and a few Bose knock offs that were actually better. But here, better marketing won out. So head to head, in an easy chair, other speakers will sound more accurate…but many people don’t live that way.
We have a Bose lifestyle 48 system up stairs where everyone moves around. We have a home theater down where everyone sits. No Bose down…just AR, Klipsch, in walls and three Velodyne subs to crack the plaster. The work out area has Bose. The sewing room where my wife sits and works, we have a regular BIC dual VC single speaker aimed at the sewing area, making a great public radio listening and background music listening speaker.
You buy and use what works best.
