I have a 2002 GMC Yukon with 195,000 miles. The oil pan is now leaking and it needs a new gasket. It has 40psi oil pressure at idle. The lifters knock when first started. Should I replace the oil pump when the pan is pulled to replace the gasket? What else should I change while the pan is off with this high milage vehicle?
Related topics
| Jeep loses oil pressure | 18 | 10659 | December 21, 2012 | |
| Replace Suburban 5.3L oil pump | 4 | 2895 | January 13, 2009 | |
| Oil pressure | 8 | 309 | August 11, 2008 | |
| 2005 GMC Yukon - Low oil pressure | 24 | 8930 | February 17, 2021 | |
| A slippery oil situation (96 Ford) | 5 | 955 | December 26, 2010 |
