Need to have my memory checked
Wife’s car that I very seldom drive 92 Buck Century. I went to the store earlier today it was raining so I had the lights on four headlight system did not notice until I turned into the parking lot that I had the high beams on anyway when I pulled in the front of the store I could see the lights in the store window just the two inside lights were on I put the low beams on and just the two outside lights were on every four headlight system I can remember on low it was the outside lights and on high all four was on am I losing some of my marbles?
Well normally yes but there are exceptions. My 86 Riviera did that with only the two inner lights coming on for high beam. I wanted all four on so re-wired the thing. Blew the relay so had to take it apart again and back to factory original. Now my 81 Olds had all four go on and I think my 86 Park Avenue was all four, but not the Riviera for some reason. I know the Regal is a lot like the Riv and the Century might be also. At any rate I think it’s normal.
Thank you I thought I remembered right if I ever saw any other way like her Buick I don’t remember according to my wife she says my marble bag has a hole n it that is getting bigger each year.
Can’t tell you which cars, but I’ve seen it this way before also.
IIRC my Corolla uses separate bulb filaments for hi vs low beam, not both on at the same time.
