My Accord would not start on its own. Engine starts when i jump start it from my other car but stops the moment i disconnect the supply. Doesnt seem to be a Dead battery. Any suggestions?
Thanks
Have you had the battery checked? When you jump it are you connecting the ground to the battery or somewhere else. If you are connecting the ground to something other than the battery I would check the ground connection from the battery at both ends for bad connection and check the cable, If not clean the battery terminals on the battery. By Clean I mean get the brushes sold at the parts store, clean the outside of the post and the inside of the connector a make sure connection is secure when reattaching.
