Greetings everyone!
I was recently gifted a 1994 Jetta GL 5-speed with about 70k miles on it. Previous owner had blown out the clutch (thanks to an original auto-adjust cable), and had just left the car to rot and I, needing a basic bit of transportation that parts were plentiful and cheap, have rescued it.
After replacing the clutch (as well as a new shifter) and new brakes, the car runs like a champ…until it began to hesitate on acceleration. After reading about the problems across the Net about the auto-adjust clutch cables and how they go bad around 70k miles, I went ahead and replaced the old cable with a manual adjust cable.
I didn’t have any hesitation on the test drive, but a new problem (or problems) has emerged as I was driving it around with the new clutch cable…
When stopped at a red light, the car idled wonderfully at approx. 1000rpms. Car purred like a kitten. After about a minute of sitting at the light with the car in neutral, the car began to lose power, rumbled, stuttered, then regained power and idled normally. After another minute, the car - again - began to lose power, rumbled, stuttered, and then stalled out completely.
On restarting the engine, putting the car into first gear and going, the most horrible smell wafted through the passenger compartment.
I noted the smell again after starting from a dead stop at another red light, but without the stall.
I had experienced the smell previously, always when in first gear, always from a dead stop, and always in first gear. I had assumed that the smell was due to the auto-adjust clutch cable was bad and eating another clutch, hence, my replacement. But when it happened after replacing the cable and, ensuring the cable was adjusted properly (that is, it lets out the clutch entirely), it still happens.
So, it looks like I have two issues, and I’m not sure they are related or not, but they have me stumped:
- The car, when warmed up, will lose power when the transmission is in neutral, and will occasionally stall.
- The car, when coming from a full stop in first gear and accelerating, will emit the most horrific smell. It doesn’t really smell like rotten eggs, but its definitely NOT good.
I am banging my head against the wall here.
I could really use any and all help with this. So, c’mon Car Talkers, let’s solve this!
