hi. I HAVE A 1989 TOYOTA COROLLA I HAVE A PROMBLEM TO ASK THE CAR KEEP SHUTTING OFF I CHANGE THE GAS FILLTER RUNS A FEW DAYS GREAT BUT IT STARTS TO SHUT OFF AGAING I HOPE YOU COULD HELP ME…
I don’t have the answer to your problem, but in the future, you’ll get better results if you don’t type in all CAPS.
Did you actually read what you wrote? It’s not even intelligible.
Anyway, we can’t diagnose the car without more information. We’ll need to know the mileage, when the car started doing this, when the car was last tuned up, etc etc.
Are you saying that each time you have changed the fuel filter, it will run a few days and begin shutting off, again? If that’s the case, the fuel tank may have a lot of loose stuff in it that keeps clogging the fuel filter. In that case, you’ll need to remove the gas tank, clean it out, and slosh a sealer around in it.
