My infiniti
my '98 infiniti I30 started staling about 2 months ago, it gets bad stalling at lights and when taking a corner. the problem is, its intermitant and no one can solve the problem for me. i tried better gas, fuel additive, etc. it’s been suggested that it may be the oxygen sensor… can anyone help me??
The problem might be with the idle air control valve. This component is what keeps the engine idling whenever the accelerator is released at a stop or while cornering.
You might try having idle air control valve removed and cleaned along with the throttle body to see if that solves the stalling problem.
Is your check engine light on? If so, what are the codes stored in the ECM?
oh, right, no check engine light, ever…
