My car has been very difficult lately
I hit a red light and as soon as I stopped, not only was the traffic light red but now my dash board was red in front of me. My car has been stalling quite often on me and I have been having with to deal with it. I immediately put my flashers on as I had a bad feeling I would be there a couple of light changes. The good news, it was so late at night and this road is not heavily traveled anyway that no cars were around or coming. So, my right leg now beginning its usual routine that it usually does everyday lately of bouncing off the seat when beginning to pump the gas pedal. The usual 5 dry deep thrusts of the pedal all the way to the floor and back up before turning the key first only to be met with a not so promising ?rrrrrrrrrrrr? that was lackluster at best, in other words my car didn?t even tease like it was trying for me. Release of the key and the only sights and sounds were the hazards resuming there ?blink blink blink? in the road and the sound they made in the car when it was not being cranked, and me beginning to bounce as the sound of the pedal squeaking thumping the floorboard began again while I continued pumping it. Now I sat in front of a green light, bouncing and pumping on a dead motor, looking in the rear view mirror as the first sight of head lights were about 150 yards behind me moving my way. They didn?t seem interested in stopping to help me because they blew by me and my stalled car pretty fast shaking us even more then we were already shaking from all the bouncing I was doing now cranking it over again. I am sure they probably could see me through the window bouncing up and down trying to get it started, especially since the hazards stop blinking when I start cranking the motor, so they saw the hazards blinking, then not blinking, then blinking again along with me bouncing like crazy!! They could have cared less, why are people this mean?? That?s ok though, I didn?t need there help anyway! I would get it started with my barefoot thumping the pedal and me bouncing up and down on the seat. Wrapping my left arm around the steering wheel and pushing the cigarette lighter in on the ash tray, I prepared myself for a third attempt at cranking my motor over as the red light above me now changed to red again to start the 2 nd cycle that I was stalled in the middle of this road late at night with no help. I stopped cranking it, dry pumped it very aggressively another 10 times and turned her over again to finally hear ?RRRRRRvrrooooom? as it staggered to life for me.
Knowing nothing about cars and being female, could somebody give me any ideas on what might be going on with it. It’s a 1984 oldsmobile delta 88 carbureted. Thanks
A lot of things can cause stalling. How long has it been since the car’s had a tune up, with new spark plugs, ignition wires, distributor cap, etc?
Your carburetor could need rebuilding, it could be the fuel pump, a vacuum line could be deteriorated and leaking, there are many things and not enough information to make a diagnosis. How is it running in general?
I think it would be cheaper in the long run for you to take it to a mechanic (preferably a good independent garage, not a chain like Midas), than continue to drive it like this, even if it takes a few hundred to diagnose and fix it. One day it may not start and leave you stranded, it could cause you to get into an accident if you can’t get out of the way of traffic, and all the constant starting is rough on your battery, starter, alternator, and engine.
Good luck
Your timing chain is shot. You also have no future writing fiction.
I’msurprisedthatanyoneactuallyspentthetimetoreadthat.Hardtolookat.
