I have a Clicking comming from the front driver side of my Car, I Had the Ford Dealer look at it and they couldn’t find anything. I took it apart and also couldn’t find anything. I replaced the brakes Rotors and cleaned the calipers. It still dose it! I can only hear it from 10 MPH- 30 MPH. After that it goes away. The dealership shop told me that it was going to cost alot to fix even though they don’t know what it is. Can some one Please help?
take off the plastic hub caps. then drive it for a while. see if it changes the noise.
What was the ‘it’ you took apart?
Check the cv-joints. If a boot has cracked, water and dirt may have penetrated and is wearing on the joint.
