IVE GOT A 97 CAMARO THAT WHILE IM DRIVING THE RADIO WILL CUT OUT FOR A FEW MINUTES AND COME BACK ON.ALSO THE POWER WINDOWS WONT WORK DURING THIS TIME.I KNOW THEY BOTH ARE HOOKED UP TO THE SAME FUSE.I CHECKED THE FUSE IT WAS FINE AND THE FUSE BOX WASNT CORRODED.WIRING IN THE BACK OF THE FUSE BOX SEEMS TO BE MAKING A GOOD CONNECTION.I STILL HAVE THE FACTORY STEREO IN THE CAR.CAN ANYONE PLEASE HELP!
Good job so far. You have it limited down, but now you need to start checking back from that fuse to the battery. I suspect it is going to be the fuse itself or something very close. Double check the wiring diagram and determine if anything else is on the circuit. Just keep looking.
I know I am a pest about it, but ALL CAPS are difficult to read. Using standard case and paragraph spacing makes messages much easier to read. Making them easier to read means more people will read it and you are more likely to get a good answer.
