Melissa with too many keys on her keychain
Having too many keys, flashlights, gadgets on the keychain can indeed damage the ignition switch. It isn’t just the dead weight pulling the key down. Watch it as you drive. All the stuff is swinging back and forth as you turn corners, go over bumps, etc. This leverages the key in the lock, which over time can cause the metal parts to deform and the ignition switch to fail. The result? The car will not start one day. And likely it will be an inopportune day for the car not to start, like you are late for work, or in the middle of a downpour.
Besides concerns about getting stranded, another incentive to keeping the weight of the keychain minimized is to consider what it would cost to replace the ignition switch. Ask your mechanic next time. He might have to replace other locks besides the ignition lock, if you want a single key to work in all the locks. So ask him: What’s the total in dollars and cents to replace the ignition switch?
hmmm … what do you think Melissa? Maybe like Tom and Ray say, you really don’t have to have all that stuff on the keychain? …
I have lots of stuff on my keychain…KEYS ! ( 3 trucks, 2 houses, work )
So to avert the impending cylinder snafu I have the two main trucks on a quick release so that only the one ignition key is in the cylinder. The rest are still on my belt loop & in my pocket.
My brother-in-law works at a large hardware store that makes keys. He had a young lady walk in wanting a key made and pulled a tangles mess out of her purse that she called her keychain. He warned her about too much weight on the keychain and she just laughed it off. He actually weighed the keychain and it was around 4 pounds. She said the only time it shuts her car off was when she drove over the speed bumps too fast on the way to her apartment.
