I need to replace my Master Window Switch on a 2012 Hyundai Sonata. I found the following video Video. I know it says that it is for 2010 and older, but I’m willing to assume that the process is very similar. My question is whether or not the process is as “easy” as he makes it looks and more importantly, what kinds of problems I might expect to run into that he doesn’t mention. Also, I am considering to buy the following replacement item: Amazon Part. Does this part seem to be the correct one?
Thank you.
The 6th generation goes from 2009 to 2014 and the master switch is in the same place on the door. If it’s different, it can’t be too different. You can figure out small differences. OEM and only 33 bucks? Nice! Good luck and let us know how it goes. If you don’t have a pry tool, get one at Amazon with the switch order. If you use a flat blade screwdriver, you might mar the door paint.
I see a lot of options for a pry tool on Amazon. Do you have any recommendations?
Something like this should work.
