Maf? p0171 p0174
my 2011 z71 ltz silverado cel came back on this morning after changing maf a couple weeks ago. a couple weeks ago it cel came on had the codes ran came back p0171 maf. switched it and reset it by pulling the battery. this morning it was back so I had the codes ran again. this time p0171 and p0174. brand new sensor k&n filter brand new. I tried pulling the sensors connection while running and truck stays on connecting and disconnecting. any ides what it could be maybe bad wire harness??
We tested K&N filters at the company I retired from.
Results?
If you want to keep birds and chipmunks out of your engine, that’s the air filter to install.
What Causes the P0174 Code?
The most common causes of the P0174 code are the following:
  • Vacuum leak due to damaged intake manifold gaskets or punctured vacuum and positive crankcase ventilation (PCV) hoses
  • Malfunctioning mass airflow (MAF) sensor
  • Clogged fuel filter
  • Failing fuel pump
  • Clogged fuel injectors
  • Failing fuel pressure regulator
  • PCM issues (e.g., software in need of an update)
  • Worn-out oxygen sensor
trying to narrow it down. I know when you have the vehicle running (most vehicles) disconnecting the maf will stall the engine. when i disconnect it stays running connecting and disconnecting while running. with a brand new maf sensor.
If you unplug the MAF sensor, the computer will substitute the lost signal with a default value programmed into the computer to keep the engine running.
