Hi, I have a no crank situation where I have done the following…
-Tested battery & starter (both good)
-Cleaned grounds (Chassis, top of transmission & from starter)
-Tested fuses
Best voltage reading going into the ignition switch is 8V. When I turn the key, I have about 6v going out to the starter.
I’m thinking the ignition switch might be fine & my problem lies with a another ground somewhere? Car is a 2012 Fiat 500.
Thoughts?
