have a 2008 sable primier that very often
I have to pull on steering wheel from side to side to unlock ignition has anyone had this problem ?
This has been the way to “unbind” locking steering columns since they started to make them. The question is, is your situation excessive?
If you make sure the steering wheel, and the front wheels, are pointed straight ahead before you shut off the ignition this problem should go away.
