A few days ago, I went to start my car and when I stuck the key in the ingnition, everything seemed normal, until I tried to start it and the ignition switch felt loose, and my engine wouldn’t turn over. I tried turning it off and starting again, and nothing. I took my key out of the ignition and everything in the car stayed on! Lights, radio, indicator lights on the dash, door chimes, everything. The only way I could turn all that stuff off was to disconnect the battery. I did have the battery tested, and it’s perfect. Since the ignition switch felt loose (no tension like when you would normally start the car) , I assume it something to do with the ignition system, or something in my steering column. Any insight?
Related topics
| Ignition | 2 | 401 | February 11, 2009 | |
| Stuck | 2 | 457 | July 11, 2010 | |
| Ignition switch question | 14 | 401 | December 26, 2007 | |
| Ignition switch stays on the on position and wont go back to the off position HELP | 3 | 2245 | August 10, 2007 | |
| What is it | 4 | 608 | October 14, 2009 |
