Leaking antifreeze in 2013 Nissan Rogue
Antifreeze leaking - oil cap milky what should I do
Head gasket’s
Is it leaking on the ground, or do you need to add coolant occasionally without signs of an internal leak? You can have it pressure tested to find the leak. After running does the motor oil on the dipstick look foamy? Oil cap being milky can be condensate.
Ok ty but it seem brought the car in March… mercanic says car was driven hot damaged the aluminum something in the engine…needs new engine …$1.900
There is your answer, the engine overheated and warped the cylinder head and possibly the block also.
Ty for replying back to me happy holidays
