Hi all,
 Here’s the problem.  I’ve got a stick-shift Honda Accord that makes knocking sounds during left hand turns— but ONLY if in gear.  If I shift to neutral or push in the clutch, no knocking.  The knocking sound is located near the right, front wheel.  It seems worse if I am also trying accelerate during the turn.  Transaxel fluid appears fine, but does have a slow leak.
I would have the CV joint checked.
I agree. Sure sounds like CV joints to me. CV joint knocking occurs under load on most vehicles.
